ask for help!!!
jing-qian
I have a very simpleprogram like the following. When I run this code under Visual Studio 2008 with IntelFortran11, it reports error of stack overflow.If I define array m as "integer m(512, 512)" but not "integer m(k(1),k(2))", the code works well. My system is Windows XP 32, and RAM is 1GB. It should not be the problem of memory. Can someone help me? In addition, I had tried to changek(1) andk(2) to 500 but not 512 in main program. And the code works well too. I am so confused!
program test
IMPLICIT REAL(A-H, O-Z)
integer k(2)
common /index/ k
k(1) = 512
k(2) = 512
call dary
end program test
subroutine dary
integer k(2)
common /index/ k
m(1,1) = 2
write(*,*) m(1,1)
end subroutine dary
You may have 1GB of RAM, but the Microsoft linker defaults the stack size to 1MB. You have several choices:
1. In the Linker > System property pages, change the Stack Reserve Size to a larger value. 100000000 (100 million) should be enough
2. Change the Fortran > Optimization > Heap Arrays property to 0, which causes such arrays to be allocated on the heap rather than on the stack
3. Change the code to:
integer, allocatable :: m(:.:)
allocate (m(k(1),k(2))
jing-qian
Steve:
Thanks a lot!!! The code works very well by following your instruction. You are great.
Jing
