assigning input file to stdin when debugging fortran in intel visual studio
Linda_S_
I want to run a fortran code in debug mode in visual studio.  the code reads input from stdin (unif 5).  I would like it to read from an input file.  Can you tell me how to assign my input file to stdin?
Steven_L_Intel1
This is VERY easy to do.
Right click on the project, select Properties > Debugging, In the field "Command Arguments" type:
< inputfilename.txt
By default it will look in the project directory.
mecej4
You can do this by setting environment variables. See the details at https://software.intel.com/en-us/node/510821 .
dboggs
Do you really want to TEMPORARILY (e.g. for debugging) want to assign a file to unit 5? I.e. not permanently, in which case you would simply open the input file to another unit number?
Linda_S_
I tried setting the environment variable FORT5 to my file name (including path).  that didn't help the situation in the debugger.  when I run the code in visual studio a command prompt window opens and the code expects input there.   I don't want to change the code to open the file explicitly.  Thanks for your hellp
Steven_L_Intel1
< inputfilename.txt
mecej4
Linda S.: Please read the documentation fully. If, as is usual these days, you used UNIT=* rather than UNIT=5 for console input in READ statements, the variable to set is FOR_READ, not FORT5. I tried this in VS 2015, and the redirection of the input worked fine.
Linda_S_
Thank you Steve
