29542 Discussions
assigning input file to stdin when debugging fortran in intel visual studio
Linda_S_
I want to run a fortran code in debug mode in visual studio.  the code reads input from stdin (unif 5).  I would like it to read from an input file.  Can you tell me how to assign my input file to stdin?
This is VERY easy to do.
Right click on the project, select Properties > Debugging, In the field "Command Arguments" type:
< inputfilename.txt
By default it will look in the project directory.
mecej4
You can do this by setting environment variables. See the details at https://software.intel.com/en-us/node/510821 .
dboggs
Do you really want to TEMPORARILY (e.g. for debugging) want to assign a file to unit 5? I.e. not permanently, in which case you would simply open the input file to another unit number?
Linda_S_
I tried setting the environment variable FORT5 to my file name (including path).  that didn't help the situation in the debugger.  when I run the code in visual studio a command prompt window opens and the code expects input there.   I don't want to change the code to open the file explicitly.  Thanks for your hellp
< inputfilename.txt
mecej4
Linda S.: Please read the documentation fully. If, as is usual these days, you used UNIT=* rather than UNIT=5 for console input in READ statements, the variable to set is FOR_READ, not FORT5. I tried this in VS 2015, and the redirection of the input worked fine.
Linda_S_
Thank you Steve
