I am porting ifort (2021.5) to ifx (2024.2.1), and regression tests are failing on floating point values throughout the code.
The porting guide (Porting Guide for ifort Users to ifx) suggests using "/assume:[no]ieee_compares" to achieve ifort floating point behaviour in ifx. Despite this I'm getting the error:
" ifx: command line error: Unrecognized keyword '[no]ieee_compares' for option '/assume' "
The fortran flags that I currently use with ifort (2021.5) are:
- /fpe:0
- /fp:precise
- /arch:SSE2
- /Qimf-arch-consistency:true
- /Qdiag-disable:10212
My questions are:
- Why is the [no]ieee_compares argument not recognised
- Confirmation on what flags to use with IFX to achieve consistent numeric behaviour with my current ifort setup.
The brackets are the way the documentation specifies optional things. In your case you want /assume:noieee_compares .
@XZ_IES if you did set:
that is of course not a valid option.
You need to set either /assume:noieee_compares or /assume:ieee_compares
Marked as done to indicate that the initial error was argument formatting. I still haven't achieved parity in results, but I'll split that into its own question as necessary.
