bad substitution -- mklvars.sh -- Automating Environment Variables -- ubuntu 11.04
diedro
hi every one,
I have some problem with mkl libriries, I had some help from Tim (thank), but I am not able to work it out. I am totally new with bash file linking ecc..
So I start to read carefully the mkl installtion guide, and here I have some problem.
At the beginnig the guide says to:
Scripts to Set Environment Variables:
I run both:
intel64/mklvars_intel64.csh intel64
intel64/mklvars_intel64.sh intel64
but I have the folowing error:
[bash]/opt/intel/composerxe-2011.0.084/mkl/bin/mklvars.sh: 12: Bad substitution
[/bash]
is this a problem?
After that I would like to do this "Automating the Process of Setting Environment Variables"
I suppose that I have to change the bash.bashrc (ubuntu 11.04), how can I do?
Do I have to simpli copy and paste:
/opt/intel/composerxe-2011.0.084/mkl/bin/mklvars.sh $* intel64
thank you
diedro
hi,
this is what I have done:
in the bash.bashrc file I have put:
[bash]##########################################################################################################
PATH="/opt/intel/composerxe-2011.0.084/mkl/bin/intel64$PATH"
source /opt/intel/composerxe-2011.0.084/mkl/bin/mklvars.sh intel64 mod
export PATH
##########################################################################################################[/bash]
I hope that it will work
Marina_S_
Hello, I have the same problem, so, did it work? 1 ########################################################################################################## 2 PATH="/opt/intel/composerxe-2011.0.084/mkl/bin/intel64$PATH" 3 source /opt/intel/composerxe-2011.0.084/mkl/bin/mklvars.sh intel64 mod 4 export PATH 5 #######################################################################################################
diedro
hi, I thinks so. Now in my bash I put: PATH="/opt/intel/bin/compilervars.sh intel64$PATH" source /opt/intel/bin/compilervars.sh intel64 source /opt/intel/mkl/bin/mklvars.sh intel64 mod lp64 export PATH it is simpler
TimP
You've got a typo there. PATH="/opt/intel/composerxe-2011.0.084/mkl/bin/intel64:$PATH but you shouldn't need that in addition to source /opt/intel/bin/compilervars.sh intel64 as the compilervars sets mklvars as well.
