29657 Discussions
bash command operates differently with CALL SYSTEM
Greynolds__Alan
The following bash command line does what I want:
LCL_ALL=C tr ...
where the ellipsis is just some arguments and IO redirection stuff. However when I issue the exact same command line from my program (compiled with 11.1 on OSX 10.6):
call system("LCL_ALL=C tr ...")
it behaves as if the LCL_ALL=C is absent. Anyone know what's happening here?
Al
jimdempseyatthecove
your system call is creating a local environment (inheriting settings from your program runtime environment)
consider using EXPORT LCL_ALL=C tr...
See: http://tldp.org/LDP/Bash-Beginners-Guide/html/sect_03_02.html
Jim Dempsey
Greynolds__Alan
I assume then I'll actually have to do somehting like:
call system("exportLCL_ALL=C && tr ...")
in order or execute the TRanslate command afterwards like my original syntax did.
Al
TimP
Or invoke a shell script which sets the desired shell for itself.
