29341 Discussions
.bashrc does not add compiler directives to path
anusiya
Hi y'all,
I have this peculiar problem. My compiler installation was without issues. When I added the line in my .bashrc "source /opt/intel/Compiler/11.1/073/bin/iccvars.sh intel64", ran "source ~/.bashrc" without any error and type "icc", I get an error "icc: command not found". Yet when I type out "source /opt/intel/Compiler/11.1/073/bin/iccvars.sh intel64" at terminal, then icc works.
If it helps my distro is Ubuntu 10.04 with 2.6.32-24 kernel.
Thanks!
Anusiya
TimP
Did you set echo temporarily in .bashrc to see if the command actually executes (and that you don't mess up PATH later)?
anusiya
Hi tim18,
If you meant I added a line 'echo $PATH' at the end of my .bashrc, yes I did that before and it displays my path variables correctly. But the complier variables are not listed there.
TimP
No, for diagnostic purposes, you would want to see each command in .bashrc executing.
