29375 Discussions
best way to set/control dll properties
bmchenry
New Contributor II
creating a number of dlls for distro in latest version and VS 2010 pro.
How does one go aboutsettingdll properties (file version, product name, product version, copyright, etc?)
Can see only 'version' in linker step.
thanks!
This is done with a "version" resource, created with the resource editor. You will need to have MS Visual C++ installed in order to use the resource editor - the Visual Studio Shell does not have it. Project > Add to Project > New > Resource File.
bmchenry
New Contributor II
hmmmm...
i do have C++, etc etc
however the confusion occurs because the 'solution' has 4 dll 'projects' and each results in a different dll name/version/etc
sowould it require 4 different 'version' resources, one for each dll?
i have been searching the web to see if someone has created a simple utility to open and edit each dll after it is built (so far all command line utilities which seems a step back to the dark ages...read the dll info allow and edit, and set it!)
Or from within Intel Fortransomething like getinforversionstring from prior thread...
http://software.intel.com/en-us/forums/showthread.php?t=82960&o=a&s=lr
except as a 'set' infoversionstring.
Yes, each project would need its own version resource. The Windows API for getting version info reads this resource. There might be some utility that adds a version resource to a DLL or EXE that doesn't have one, but I am not familiar with any.
The .rc file is really just a text file so you could have a script that runs at the start to build it. You can also #include a section from another file so that could be used to share the version info.
bmchenry
New Contributor II
FYI for other Intel Fortran users wanting to change/modify version information in dlls/exes etc:
Found a program Resource Tuner by HeavenTools that does the trick w/o me having to mess with adding C++ etc to solutions/project/etc.
(i needed to add the version information quickly)
Resource Tunerrequiresan extra external step to add the information to the dll/exe but for now that works for me.
Note that the 'console version' of Resource Tuner is required toadd version information
Intel fortran projects/solutions create dlls and exe's without anyversion information so the information has to be added.
once added then the version informationcan be edited by either version of Resource tuner.
At some point i exppect i will revisit theproject/solutiuonand addC++ components to add the version information w/o requiring the extra external step.
i will then also try to remember topost up a sample mixed language project so others can easily add version information
B
and note, i am not affiliated with heaventools/resource tuner in any way. just sifted through a few offerings on the web and found this one does the trick.
DavidWhite
Valued Contributor II
While you need C++ installed, adding the resource component into a Fortran DLL does not need any C++ code. Just add the resource to your project and edit the properties from the menu in VS. No need to know any C++ either. Note, as mentioned before, this requires the independent VS install, rather than the bundled version with IVF. All of my DLL apps have this info embedded.
David
bmchenry
New Contributor II
I tried adding a version.rc to a project and it compiles fine, however the resulting exe/dll still doesn't have the 'version' information inserted.
Iright click on the file it does not displays the information.
If i open with Resource Tuner it DOES appear to have the informaiton inserted.
Any idea how to get it to show in general w/o having to resort to an external program to add/edit/etc?
I insert (the attachement looked awful!)a sampleversion.rc text file (with my information removed and generic stuff inserted).
Is there something missing?
thanks
// Version
VS_VERSION_INFO VERSIONINFO
FILEVERSION 1,0,0,0
PRODUCTVERSION 1,0,0,0
FILEFLAGSMASK 0x3fL
#ifdef _DEBUG
FILEFLAGS 0x1L
#else
FILEFLAGS 0x0L
#endif
FILEOS 0x4L
FILETYPE 0x1L
FILESUBTYPE 0x0L
BEGIN
BLOCK "StringFileInfo"
BEGIN
BLOCK "040904b0"
BEGIN
VALUE "Comments", "Sample Application\0"
VALUE "CompanyName", "Your Company Here\0"
VALUE "FileDescription", "All about this file\0"
VALUE "FileVersion", "1, 0, 0, 0\0"
VALUE "InternalName", "filename\0"
VALUE "LegalCopyright", "Copyright (C) 2011 You or Your company\0"
VALUE "OriginalFilename", "file.EXE\0"
VALUE "ProductName", "whatever you name your Product\0"
VALUE "ProductVersion", "1, 0, 0, 0\0"
END
END
BLOCK "VarFileInfo"
BEGIN
VALUE "Translation", 0x409, 1200
END
END
Did the .rc compile into a .res and did the .res get linked in?
bmchenry
New Contributor II
yes and yes.
and with the external tool (Resource Tuner) i see the information is in the exe (in the sample i am recompiling an exeto try it out)
however i'd like the version informationto be seen by anyone who right clicks on the exe.
If you right click and select Properties > Details, does it show up there? If the version info is in the EXE it ought to show up.
bmchenry
New Contributor II
no it does not contain any version information.
i set up a sample from an old solution/project file.
i attach the file.
brian
