How does one go aboutsettingdll properties (file version, product name, product version, copyright, etc?)
Can see only 'version' in linker step.
thanks!
i do have C++, etc etc
however the confusion occurs because the 'solution' has 4 dll 'projects' and each results in a different dll name/version/etc
sowould it require 4 different 'version' resources, one for each dll?
i have been searching the web to see if someone has created a simple utility to open and edit each dll after it is built (so far all command line utilities which seems a step back to the dark ages...read the dll info allow and edit, and set it!)
Or from within Intel Fortransomething like getinforversionstring from prior thread...
http://software.intel.com/en-us/forums/showthread.php?t=82960&o=a&s=lr
except as a 'set' infoversionstring.
The .rc file is really just a text file so you could have a script that runs at the start to build it. You can also #include a section from another file so that could be used to share the version info.
Found a program Resource Tuner by HeavenTools that does the trick w/o me having to mess with adding C++ etc to solutions/project/etc.
(i needed to add the version information quickly)
Resource Tunerrequiresan extra external step to add the information to the dll/exe but for now that works for me.
Note that the 'console version' of Resource Tuner is required toadd version information
Intel fortran projects/solutions create dlls and exe's without anyversion information so the information has to be added.
once added then the version informationcan be edited by either version of Resource tuner.
At some point i exppect i will revisit theproject/solutiuonand addC++ components to add the version information w/o requiring the extra external step.
i will then also try to remember topost up a sample mixed language project so others can easily add version information
B
and note, i am not affiliated with heaventools/resource tuner in any way. just sifted through a few offerings on the web and found this one does the trick.
David
I tried adding a version.rc to a project and it compiles fine, however the resulting exe/dll still doesn't have the 'version' information inserted.
Iright click on the file it does not displays the information.
If i open with Resource Tuner it DOES appear to have the informaiton inserted.
Any idea how to get it to show in general w/o having to resort to an external program to add/edit/etc?
I insert (the attachement looked awful!)a sampleversion.rc text file (with my information removed and generic stuff inserted).
Is there something missing?
thanks
// Version
VS_VERSION_INFO VERSIONINFO
FILEVERSION 1,0,0,0
PRODUCTVERSION 1,0,0,0
FILEFLAGSMASK 0x3fL
#ifdef _DEBUG
FILEFLAGS 0x1L
#else
FILEFLAGS 0x0L
#endif
FILEOS 0x4L
FILETYPE 0x1L
FILESUBTYPE 0x0L
BEGIN
BLOCK "StringFileInfo"
BEGIN
BLOCK "040904b0"
BEGIN
VALUE "Comments", "Sample Application\0"
VALUE "CompanyName", "Your Company Here\0"
VALUE "FileDescription", "All about this file\0"
VALUE "FileVersion", "1, 0, 0, 0\0"
VALUE "InternalName", "filename\0"
VALUE "LegalCopyright", "Copyright (C) 2011 You or Your company\0"
VALUE "OriginalFilename", "file.EXE\0"
VALUE "ProductName", "whatever you name your Product\0"
VALUE "ProductVersion", "1, 0, 0, 0\0"
END
END
BLOCK "VarFileInfo"
BEGIN
VALUE "Translation", 0x409, 1200
END
END
and with the external tool (Resource Tuner) i see the information is in the exe (in the sample i am recompiling an exeto try it out)
however i'd like the version informationto be seen by anyone who right clicks on the exe.
