29253 ディスカッション
bitmap files in 256 mode
rswy
ビギナー
797件の閲覧回数
I had posted a message some time back regarding saving bitmap images in 256 color mode.There was a reply posted but unfortunately am still not able to save the images right.I would appreciate any pointers or suggestions to get the code working right.I'd also like to know if the sample code in the XFT webpage worked for the 256 color mode or required any small alterations to work right.
--rswy
0 件の賞賛
2 返答(返信)
Jugoslav_Dujic
高評価コントリビューター II
797件の閲覧回数
Thanks for the "bug report"; I'll investigate it and let you know when I find the solution.
Jugoslav
Jugoslav_Dujic
高評価コントリビューター II
797件の閲覧回数
Who says SDK C samples are supposed to work? :-). Here's the corrected version. iDepth argument e{1,4,8,16,24,32} also works now; if absent, screen color depth is used.
返信
