bitmap files in 256 mode
rswy
I had posted a message some time back regarding saving bitmap images in 256 color mode.There was a reply posted but unfortunately am still not able to save the images right.I would appreciate any pointers or suggestions to get the code working right.I'd also like to know if the sample code in the XFT webpage worked for the 256 color mode or required any small alterations to work right.
--rswy
Jugoslav_Dujic
Valued Contributor II
Thanks for the "bug report"; I'll investigate it and let you know when I find the solution.
Jugoslav
Jugoslav_Dujic
Who says SDK C samples are supposed to work? :-). Here's the corrected version. iDepth argument e{1,4,8,16,24,32} also works now; if absent, screen color depth is used.
