buffered IO
Scott_L_
The code I am working on is running fine on Windows.  When it is ported and  built on Linux, it fails on the  on eof our unit tests  with an error  – cannot write a file to working directory - in a directory that is open to write in.
Running the same Linux executable with strace, I get "too many open files" error trying to write the file.
Changing all buffered IO open statements from BUFFERCOUNT=4 to =1, now it runs with no errors.   Is there any known issue with buffered IO on Linux as opposed to WIndows?
thanks,
Scott
Kevin_D_Intel
I reproduced the behavior described; however, on Linux I'm finding that it does matter that files are present in the lower level junk2* subdirectories. When all junk2* subdirectories are empty the entire directory tree "junk" is removed. On Windows, everything is removed with and without files present at that lowest level. I reported this to Development and will let you know whether there's a work around.
(Internal tracking id: DPD200419358)
Kevin_D_Intel
Development confirmed there is a defect in the Linux implementation of GETFILEINFOQQ preventing recursive usage. This will be fixed in a future update.
Scott_L_
Thanks for your help Kevin.   I just want to confirm something about static/automatic locals in recursive routines.   I am compiling with the global compiler option /save for legacy routines relying on it.  Where I have functions or subroutines declared recursive, does ifort force all local variables in that routine to be automatic in spite of the global compiler option /save?   It seems to work this way, but wanted to be sure.  Adding AUTOMATIC to the test routine did not seem to change anything.
thanks again.
scott
Kevin_D_Intel
