bug? re: array dimensions
israelhsu
I'm not a Fortran90 expert, so I don't know if the program below has an illegal declaration or if the compiler has a bug:
program test
integer, parameter, dimension(3) :: nxyz = 32
integer, parameter :: nx=2, ny=2, nz=2
real, parameter, dimension(3) :: xyz_range = (/ nx, ny, nz /)
real, parameter, dimension(3) :: b0 = nxyz*nxyz/xyz_range
end program
The compiler (Intel Fortran compiler 8.0 on RedHat 9) outputs:
fortcom: Error: ftest.f90, line 5: This operator is invalid in a constant expression evaluation.
compilation aborted for ftest.f90 (code 1)
Thanks in advance for your help.
--Israel Hsu
[email protected]
Message Edited by israelhsu on 01-21-2004 11:55 AM
Message Edited by israelhsu on 01-21-2004 12:01 PM
nxyz is an array - I don't think you wanted the dimension(3) on it's declaration.
It's not clear to me what you want here. What do you expect the value of b0 to be?
It seems that the compiler is objecting to the mixed integer-real array arithmetic here. This may be a bug, but my head is spinning trying to make sense of it. However, this works:
real, dimension(3), parameter :: b0 = real((nxyz * nxyz)) /xyz_range
