29559 Discussions
bug report: intel fortran compiler 9.1, intrinsic function dcosd
shiyin
Try this code:
program testRa
double precision:: ra
Ra=359.9
print *,dcosd(Ra),dcosd(Ra-360)
end
compile with ifort (v9.1)
The output is
0.768461121150065 0.999998476727358
The first number is obviously wrong!!!
Using compiler ifc7.1, the output is correct.
shiyin
ps. It is the compiler for Linux.
TimP
When you take so many risks in your code, a number of things can go wrong, depending on the options you choose, and exact compiler version. What happens if you declare dcosd, and change 359.9 to a double precision constant?
I don't see a problem until the 10th digit when I run this, but I'm sure I don't have the same compiler build.
dcosd is an intrinsic so you don't need to declare it. Tim is correct that the 359.9 should be 359.9D0, but that doesn't make a large difference.
I can't reproduce the results you are seeing. I get:
0.999998476727358 0.999998476727358
if I use 359.9D0 I get:
0.999998476913288 0.999998476913288
What is the exact version of the compiler you are using? If 9.1.037, which is the latest, please send a test case to Intel Premier Support.
