29652 Discussions
Create directories using INTEL FORTRAN
bsi
This is hopefully a simple question:
During the execution of my application I need to createsome text files and save data in those. The data files need to becreatedin a subdirectory of the current directory (ie where the input data file is located). The problem I have is that the subdirectory cannot be created before the execution of the program since the name etc is not known before hand.
The question: Is there a way during the execution of an application to create a directory?
Any suggestion will be greatly appreciated.
Petros
Sure - the Win32 API routine CreateDirectory, defined in module kernel32 Quick example
program credir
use kernel32
implicit none
integer(BOOL) ret
ret = CreateDirectory("subdir"C, NULL)
if (ret == 0) then
print *, "CreateDirectory failed, status = ", GetLastError()
end if
end program credir
