bug with copying a large array
kay-diederichs
I found a problem with ifort 18.0.3 on a x86_64 machine.  This code
PROGRAM bug
  IMPLICIT NONE
  INTEGER(SELECTED_INT_KIND(9)) :: i
  INTEGER(SELECTED_INT_KIND(18)) :: nobs,k8=10000000,i8
  INTEGER, ALLOCATABLE :: obs(:),temp_obs(:)
  ALLOCATE(obs(10000000))
  nobs=0
  DO i8=1,INT(HUGE(i),KIND=8)*2 - 1000000
    i=1   ! replacement for READ(...)i
    nobs=nobs+1
    IF (nobs==k8) THEN
      k8=2*k8
    END IF
    IF (nobs>SIZE(obs,KIND=8)) THEN
      ALLOCATE(temp_obs(2*SIZE(obs,KIND=8)))
      temp_obs(:SIZE(obs,KIND=8))=obs  ! temp_obs(1:SIZE ... fixes this!
      PRINT*,temp_obs(1),nobs
      CALL MOVE_ALLOC(temp_obs,obs)
      PRINT*,obs(1),nobs
      IF (obs(1) /= 1) STOP 'this is wrong'
    END IF
    obs(nobs)=i
  END DO
  STOP 'finished without error'
END PROGRAM bug
shows that the
line does not work right - it seems to zero the temp_obs array, instead of copying the obs array.
The bug is not triggered if the line is replaced by
temp_obs(1:SIZE(obs,KIND=8))=obs
The bug is not present in gfortran.
Warning: you need a machine with enough RAM - 24 GB is enough; maybe 16GB suffices.
Kay
