build that will work on XP
Rob1
I remember seeing a sticky on here a few months ago that if using vs2012 and/or the latest intel compiler that extra libraries are needed to get the build to work on windows XP.
now i can't find this thread, and the search tool is very unhelpful since i can't sort the results at all.  (i have always found this forum to be confusing and difficult to use).
help?
thanks,
rob
TimP
Rob1
Thanks for the info TimP.
However I am having problems getting this to work.
The fortran exe that i build works fine on win7, but when run on XP i get "The specified executable is not a valid application for this OS platform".
In your second link it says that not having VS2012 SP1 can cause errors similar to this, but i have VS2012 11.0.60315.01 Update 2.
The first link looks promising, however i cannot locate the "Platform Toolset" field that is shown in order to select the "Visual Studio 2012 - Windows XP (v110_xp)" option.  For me under Configuration Properties>General all i have is 6 items, not the 8 that is shown.  Is this option hidden somwhere else?
thanks,
rob
You should not need the Platform Toolset option - it isn't available in a Fortran project. Can you run Dependency Walker on the XP system and have it analyze your executable there? It may give you a hint.
Rob1
I don't see anything significant in dependency walker.  Just IESHIMS.dll and WER.dll (i've never heard of wer before).
Attached is the dependency walker output in a zip file.
thanks
Hmm - indeed nothing to see there.Let me think about this some more. Might need to find a way to link to the alternate SDK that Update 2 provides, but I don't know where it gets put.
Neels
New Contributor II
I have the same problem and also have VS2012 update 2. I do not have access to the WinXP machine.
Neels
Rob1
Any ideas?
Will reverting back to update 1 work?
I would expect that to make it worse.  Let me do some experiments and see if I can figure out what's happening.
Try this.  In Visual Studio. select Tools > Options > Intel Composer XE > Visual Fortran > Compilers. On the Win32 tab, click the ... button to the right of Libraries.  Add the following line at the TOP of the list:
C:\Program Files (x86)\Microsoft SDKs\Windows\v7.1A\Lib
If you are on a 32-bit system, then remove the " (x86)".
Now rebuild your application. Will it run on XP?
Rob1
I am on a 64 bit system, so i did as you said (see attached "setdirlist.png").  After this change I cleaned the solution and did a build.
I get the same result as with the old exe however.  On a win7 machine both work, but If i try to run the exe from explorer on the XP machine i get the same message with the old and the new exe (see attached "error2.png").
I suppose I should have asked first - does the folder I named exist?
Rob1
yes, i have this directory: C:\Program Files (x86)\Microsoft SDKs\Windows\v7.1A\Lib
Under "Program Files", i only have a v6.0A directory.  So i assumed that i should use "Program Files (x86)".
andrew_4619
Quick question if you then copy the exe file back from the XP machine to the win7 machine does it still run? Just a thought that the file has been corrupted in transit.....
Rob1
Yes, i just tried copying them back to the win7 machine and they work.
Can you try a simple "Hello World" application and see if the same problem occurs?
Rob1
My hello world exe exhibits the same behavior.  Runs fine on my win7 machine, but i get "... not a valid win32 application" on the XP machine.
I started a new project and used the stock code plus a read:
! hiworld.f90
! FUNCTIONS:
! hiworld - Entry point of console application.
! PROGRAM: hiworld
! PURPOSE: Entry point for the console application.
program hiworld
implicit none
! Variables
! Body of hiworld
print *, 'Hello World'
read(*,*)
end program hiworld
Ok, try this - seems to work for me.
Right click on the project and select Properties. Go to Linker > System.  Change Subsystem to "Not Set".  Now go to Linker > Command Line. If it is a Console application, type in the Additional Options field:
/SUBSYSTEM:CONSOLE,"5.01"
if it is a Windows GUI or QuickWin app, type in:
/SUBSYSTEM:WINDOWS,"5.01"
Neels
New Contributor II
That works for me, thanks Steve.
Neels
Rob1
Works for me too.
Thanks Steve!!!
Ok, great.  This was a tidbit I missed from my initial review of the changes Microsoft made. I have now updated the article.
