29386 Discussions
c++ calling fortran dll linker error
pradeepnatekar
I am using MS VS 6.0 for a c++ application which need to call a dll built with IVF (Version 9.0.2945.2003). The code which I have in C++ and Fortran is given below.
C++:
#include "stdafx.h"
#include
extern "C"
void __cdecl TestCode();
int main(int argc, char* argv[])
TestCode();
return 0;
FORTRAN:
subroutine TestCode
!DEC$ ATTRIBUTES DLLEXPORT::TestCode
!DEC$ ATTRIBUTES C, ALIAS: 'TestCode':: TestCode
call MainExp()
end subroutine TestCode
The TestCode.dll and .lib are in path of the C++ exe. Building the project gives following error.
Test.obj : error LNK2001: unresolved external symbol _TestCode
Debug/Test.exe : fatal error LNK1120: 1 unresolved externals
Error executing link.exe.
Do I need to change something in vc++ project settings to get it right. Please help.
Pradeep
Either add the leading underscore in the ALIAS attribute or, preferably, add the DECORATE attribute as well.
pradeepnatekar
Steve
I have made the changes as follows:
subroutine
TestCode
!DEC$ ATTRIBUTES DLLEXPORT:: TestCode
!DEC$ ATTRIBUTES C, DECORATE, ALIAS: '_TestCode':: TestCode
!call MainExp()
print*, "Say Hello from Fortran"
end subroutine
TestCode
Still the linker gives error.
I said "either". Don't do both. Either add the underscore or add DECORATE, but both together will give you a symbol with two leading underscores.
pradeepnatekar
Steve I tried both. Its not working. Do I need to change something in c++ project settings?
Are you linking the export library (.lib) created by the Fortran project in the C++ project?
Be sure that you do not do BOTH of the things I mentioned. Use DECORATE and have the ALIAS omit the underscore.
pradeepnatekar
Steve,
IusedDECORATE and ALIAS without the leading underscore. The only thing I forgot to do was to include the .lib in c++ project. Now I have added .lib to roject and kept .lib and .dll in path of c++ exe. It works fine now. Thanks for your help. Final code is as below:
---------------------Fortran Code--------------------
subroutine
TestCode
!DEC$ ATTRIBUTES C, DECORATE, ALIAS:'TestCode':: TestCode
end subroutine
TestCode
#include
"stdafx.h"
------------------C++ code -------------------
extern
"C"
int
TestCode();
return 0;
