call c_f_pointer
Brett_Wilt
Upgraded to later version of Intel Fortran compiler. i now receive error:
There is no matching specific subroutine for this generic subroutine call.   [C_F_POINTER]
          call c_f_pointer(gfld%discipline,grbdisc)
Here is my code:
use m_gribfield
use, intrinsic:: iso_c_binding
type(gribfield), pointer:: gfld
Any thoughts? The previous linux compiler was 2011.3.174, and it compiles ok with that. I included the structure below.
gfld%discipline is integer(g2int). This argument is required to be type(c_ptr). I don't know how you have declared grbdisc. As it happened, we tightened up C_F_POINTER (and C_F_PROCPOINTER) in this regard in Update 4 to Composer XE 2011, so you had just missed the change in the earlier compiler. You may need to use TRANSFER, though I will caution you that you've hardwired 32-bitness into this code and it will be very wrong if you build for x64.
