29487 Discussions
call subroutine in dll A from subroutine in dll B
Erik_J_
I have some LAPACK routines (F95 or F77?) in a DLL and write some stubs to cal the LAPACK routines that I call  from C#
I put those stubs in another DLL.
At least, that's the general idea to solve the problem of having to recompile ALL the Fortran many times, when I put everything in one DLL.
I want to build the LAPACK dll only once and develop the stubs separately.
How would I do this calling of the LAPACK routines?
I was pointed to "modules" and to "loadlibrary" which seem to be quite different approaches.
I use VS2015 on win10 and call from c#, which goes well.
Arjen_Markus
Just you would call routines in a static library. The routines in the DLL with LAPACK should be exported, but that is matter of linking it. (You may want to use a .def file for this). Linking is done against the corresponding import library (.lib instead of .dll). No need to explicitly load the DLL via LoadLibrary.
I wouldn't use a ,def file for this - just link one DLL against the other's export library.
