29386 Discussions
call windows system command through fortran without showing the cmd window and output the result to an external file
xim__poil
I'm doing a little project using fortran. A part of the code is designed to check the PC's mac address. Currently, I'm using call system command as follows:
CALL SYSTEM("ipconfig -all >result.tmp")
Above code will invoke the windows ipconfig-all command and output the information to an external file result.tmp. Later this file will be read to check the mac address.
Above works, except one annoying thing. The fortran code will be compiled as a dll and used by another C# program. The annoying thing is, whenever above code is executed in the C# program, a console window will be prompted shortly and then closed. I searched the forum to find if there is some way to disable the window prompt, it turns out there is some solution in the following link:
https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/506794?language=en-us&https=1#
I tried that solution, it works fine for the system command "ipconfig -all", but I did not figure out how to output the result to an external file.  Does anyone can give me some hints on how to achieve that ?
Paul_Curtis
Valued Contributor I
Here is a module to access MAC adapter info directly from Fortran, much easier than what you are doing now.
MODULE MAC
    USE ifwinty
    USE charfunc
    IMPLICIT NONE
    PUBLIC GetMacInfo       !, PortExists
    PRIVATE
    SAVE
    INTEGER, PARAMETER :: MAX_ADAPTER_DESCRIPTION_LENGTH = 128
    INTEGER, PARAMETER :: MAX_ADAPTER_NAME_LENGTH        = 256
    INTEGER, PARAMETER :: MAX_ADAPTER_ADDRESS_LENGTH     =   8
    INTEGER, PARAMETER :: MIB_IF_TYPE_ETHERNET           =   6  ! Ipifcons.h
    TYPE IP_ADDRESS_STRING
        CHARACTER(LEN=16) :: String
    END TYPE IP_ADDRESS_STRING
    TYPE IP_MASK_STRING
    END TYPE IP_MASK_STRING
    TYPE t_IP_ADDR_STRING
        INTEGER (LPLONG)         :: pNext
        TYPE (IP_ADDRESS_STRING) :: IpAddress
        TYPE (IP_MASK_STRING)    :: IpMask
        INTEGER (DWORD)          :: Context
    END TYPE t_IP_ADDR_STRING
    TYPE t_IP_ADAPTER_INFO
        INTEGER(LPLONG)         :: pNext
        INTEGER(DWORD)          :: ComboIndex
        CHARACTER(LEN=MAX_ADAPTER_NAME_LENGTH+4)        :: AdapterName
        CHARACTER(LEN=MAX_ADAPTER_DESCRIPTION_LENGTH+4) :: Description
        INTEGER(UINT)           :: AddressLength
        INTEGER(BYTE)           :: Address(MAX_ADAPTER_ADDRESS_LENGTH)
        INTEGER(DWORD)          :: Index
        INTEGER(ULONG)          :: iType
        INTEGER(ULONG)          :: DhcpEnabled
        INTEGER(LPLONG)         :: pCurrentIpAddress
        TYPE(t_IP_ADDR_STRING)  :: IpAddressList
        TYPE(t_IP_ADDR_STRING)  :: GatewayList
        TYPE(t_IP_ADDR_STRING)  :: DhcpServer
        INTEGER(BOOL)           :: HaveWins
        TYPE(t_IP_ADDR_STRING)  :: PrimaryWinsServer
        TYPE(t_IP_ADDR_STRING)  :: SecondaryWinsServer
        INTEGER(ULONG)          :: LeaseObtained
        INTEGER(ULONG)          :: LeaseExpires
    END TYPE t_IP_ADAPTER_INFO
    !   must link with IpHlpApi.lib to access this API function;
    !   this interface is not included in ifwinty
    INTERFACE
        INTEGER(BOOL) FUNCTION GetAdaptersInfo (arg1, arg2)
            USE ifwinty
            !DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'GetAdaptersInfo' :: GetAdaptersInfo
            INTEGER(LPLONG) :: arg1
            INTEGER(LPLONG) :: arg2
        END FUNCTION
    END INTERFACE
CONTAINS
    SUBROUTINE GetMacInfo (hwnd, id)
        USE contwrap
        IMPLICIT NONE
        !   dialog window handle and set of static-text IDs for display
        INTEGER(HANDLE), INTENT(IN)         :: hwnd
        INTEGER, INTENT(IN), DIMENSION(4)   :: id
        CHARACTER(LEN=200)                  :: msg
        INTEGER                             :: i, nc, count
        INTEGER, PARAMETER                  :: acount = 16
        TYPE(t_IP_ADAPTER_INFO),ALLOCATABLE :: ai(:)
        count = 0
        !   allow for multiple adapters
        ALLOCATE (ai(acount))
        nc = SIZEOF(ai)
        IF (GetAdaptersInfo(LOC(ai), LOC(nc)) == 0) THEN
            DO i = 1, acount
                SELECT CASE (ai(i)%iType)
                CASE (MIB_IF_TYPE_ETHERNET)
                    !   line 1: description and MAC address
                    !nc = INDEX(ai(i)%Description, CHAR(0)) - 1
                    !WRITE (msg, '(A,",  ",5(Z2.2,"-"),Z2.2)') &
                    !    ai(i)%Description(1:nc),              &
                    !    ai(i)%Address(1:ai(i)%AddressLength)
                    msg = ai(i)%Description(1:nc)
                    count = count + 1
                    CALL StaticSetText (hwnd, id(count), msg)
                    CALL ControlSetVisible (hwnd, id(count), .TRUE.)
                    !   line 2: IP and Gateway addresses
                    WRITE (msg, '("IP Addr: ",A,"  Gateway: ",A)')  &
                        ai(i)%IpAddressList%IpAddress%string,       &
                        ai(i)%GatewayList%IpAddress%string
                    CALL remove_nulls (msg)
                    count = count + 1
                    IF (count >= 4) EXIT
                END SELECT
                IF (ai(i)%pNext == NULL) EXIT
            END DO
        END IF
        DEALLOCATE (ai)
    END SUBROUTINE GetMacInfo
END MODULE MAC
Paul_Curtis
MODULE MAC
    USE ifwinty
    USE charfunc
    IMPLICIT NONE
    PRIVATE
    SAVE
    TYPE IP_MASK_STRING
    INTERFACE
            USE ifwinty
        END FUNCTION
    END INTERFACE
CONTAINS
        USE contwrap
        IMPLICIT NONE
        count = 0
        nc = SIZEOF(ai)
            DO i = 1, acount
                    count = count + 1
                    count = count + 1
                END SELECT
            END DO
        END IF
        DEALLOCATE (ai)
END MODULE MAC
Steve_Lionel
I agree with Paul that the Windows API is the way to go. For your general question, the problem is that SYSTEM doesn't execute a shell command, so you can't do redirection. I looked at ShellExecute, but it too doesn't support redirection. You'd probably have to go to CreateProcess and specify a file handle as standard output.
Arjen_Markus
Actually, if you need redirection, then using the routine execute_command_line will do exactly what you want:
program run_command
    implicit none
    call execute_command_line( "ipconfig -all > cmd.out" )
end program run_command
jimdempseyatthecove
Simple hack to try
call execute_command_line( "start /B ipconfig -all > cmd.out" )
*** Note, program execution follows while started program is running.
Therefore, you will need to determine when the started program completes.
Possible method is to delete the output file (cmd.out), then execute the start, then
loop
     attempt to open existing file (cmd.out) for exclusive use
     on success, break
end loop
Jim Dempsey
xim__poil
That exactly was how I implemented at the beginning. However, it turns out the getAdapterInfo method performs much faster than the execute_command_line( "start /B ipconfig -all > cmd.out" ) method, mainly because there is no associated file operation. As a result, I adopted the getAdapterInfo method for fast operation (the method will be invoked in a loop)
xim__poil
MODULE MAC
    USE ifwinty
    USE charfunc
    IMPLICIT NONE
    PRIVATE
    SAVE
    TYPE IP_MASK_STRING
    INTERFACE
            USE ifwinty
        END FUNCTION
    END INTERFACE
CONTAINS
        USE contwrap
        IMPLICIT NONE
        count = 0
        nc = SIZEOF(ai)
            DO i = 1, acount
                    count = count + 1
                    count = count + 1
                END SELECT
            END DO
        END IF
        DEALLOCATE (ai)
END MODULE MAC
Thank you for your suggestion Paul!. I've made a try, but the compiler reported an error, saying that Check include path for [CHARFUNC] and [ifwinty]. Besides, in your provided sample code, it is said "IpHlpApi.lib must be linked", Unfortunately, I searched the library file but it returns nothing. There is a IpHlpApi.dll located under windows/system32 though.  I'm not quite familiar with fortran coding, will you give me some hints how to run your code? Truly appreciated for your help.
xim__poil
program run_command
    implicit none
Thanks for your suggestion. Unfortunately I'm using IVF, which does not support the command execute_command_line yet
Arjen_Markus
Which version? The routine is a standard routine in Fortran 2008. It was already available in IVF 2017. A workaround might be to put the ipconfig command with the redirection in a batch file (perhaps written on the fly). Not very elegant and you may need to specify the command as: "cmd /c name-of-batch.bat", but it ought to work ;).
mecej4
You can see from the release notes for IFort 16.0 that EXECUTE_COMMAND_LINE was added in that version:
     https://software.intel.com/en-us/articles/intel-visual-fortran-compiler-160-for-windows-release-notes-for-intel-parallel-studio-xe#f08_f15
xim__poil
I'm still using IVF 2013 -_-! Maybe I should update to IVF 2017 in future
Paul_Curtis
My module was extracted from a larger program in which the recovered MAC info text was passed to a dialog for display.  You can ignore (ie, delete) the reference to charfunc, and deal with the MAC strings however you want (ie, perhaps as returned args).  I have attached IPHlpApi.lib as a zipfile.
xim__poil
Thanks for the iPHlpApi.zip. I slightly modify the program as follows:
PROGRAM MAC
USE ifwinty
IMPLICIT NONE
INTEGER, PARAMETER :: MAX_ADAPTER_DESCRIPTION_LENGTH = 128 !// arb.
INTEGER, PARAMETER :: MAX_ADAPTER_NAME_LENGTH        = 256 !// arb.
INTEGER, PARAMETER :: MAX_ADAPTER_ADDRESS_LENGTH     =   8 !// arb.
TYPE :: IP_ADDRESS_STRING
  CHARACTER (4) :: String(4)
END TYPE
TYPE :: IP_MASK_STRING
END TYPE
TYPE :: t_IP_ADDR_STRING
END TYPE
TYPE :: t_IP_ADAPTER_INFO
 INTEGER (DWORD) :: ComboIndex
 CHARACTER (LEN = MAX_ADAPTER_NAME_LENGTH + 4) :: AdapterName
 CHARACTER (LEN = MAX_ADAPTER_DESCRIPTION_LENGTH + 4) :: Description
 INTEGER (UINT) :: AddressLength
 INTEGER (BYTE) :: Address(MAX_ADAPTER_ADDRESS_LENGTH)
 INTEGER (DWORD) :: Index
 INTEGER (ULONG) :: iType
 INTEGER (ULONG) :: DhcpEnabled
 INTEGER (LPLONG) :: pCurrentIpAddress
 TYPE (t_IP_ADDR_STRING) :: IpAddressList
 TYPE (t_IP_ADDR_STRING) :: GatewayList
 TYPE (t_IP_ADDR_STRING) :: DhcpServer
 INTEGER (BOOL) :: HaveWins
 TYPE (t_IP_ADDR_STRING) :: PrimaryWinsServer
 TYPE (t_IP_ADDR_STRING) :: SecondaryWinsServer
 INTEGER (ULONG) :: LeaseObtained
 INTEGER (ULONG) :: LeaseExpires;
END TYPE
INTERFACE
 INTEGER (BOOL) FUNCTION GetAdaptersInfo(arg1, arg2)
 USE ifwinty
 INTEGER (LPLONG) :: arg1
 INTEGER (LPLONG) :: arg2
 END FUNCTION
END INTERFACE
TYPE (t_IP_ADAPTER_INFO) :: AdapterInfo(16)
CHARACTER(LEN=17)::MACAddr(16)
CHARACTER(LEN=500) :: str1,str2
TYPE (t_IP_ADDR_STRING) :: CurrentIpAddress
INTEGER (DWORD) :: dwRetVal
INTEGER (BOOL) :: iret
INTEGER :: i,j,m,k
LOGICAL::search4Next
CHARACTER(Len=500)::info_out(50)
dwRetVal = sizeof(AdapterInfo)
!dwRetVal=10240
PRINT*,dwRetVal
!PRINT*,AdapterInfo
iret = GetAdaptersInfo(LOC(AdapterInfo), LOC(dwRetVal))
IF (iret /= 0) STOP 'Error'
DO i = 1, 16
! PRINT *, AdapterInfo(1)%pNext
! PRINT *, AdapterInfo(1)%ComboIndex
! PRINT *, AdapterInfo(1)%AddressLength
 PRINT *, AdapterInfo(i)%Description(1:INDEX(AdapterInfo(i)%Description(1:128), CHAR(0)))
 PRINT *, AdapterInfo(i)%ITYPE
 PRINT '(5(Z2.2,"-"), Z2.2)', AdapterInfo(i)%Address(1:AdapterInfo(i)%AddressLength)
 write(MACAddr(i),'(5(Z2.2,"-"), Z2.2)') AdapterInfo(i)%Address(1:AdapterInfo(i)%AddressLength)
 MACAddr(i)=TRIM(MACAddr(i))
 j=1
 str2=""
 str1=TRIM(MACAddr(i))
 DO m=1,100
     k=INDEX(str1(j:),"-")
     IF(k>0)THEN
         str2=TRIM(str2)//str1(j:j+k-2)
     ELSE
         str2=TRIM(str2)//str1(j:)
         !convert to small caps
         CALL hadware_local_upper2lower(str2)
         info_out(i)=TRIM(str2)
         search4Next=.TRUE.
         EXIT
     ENDIF
     j=j+k
 ENDDO
 IF (AdapterInfo(i)%pNext == NULL) THEN
    EXIT
    read(*,*)
 ENDIF
END DO
read(*,*)
STOP
    END PROGRAM MAC
    SUBROUTINE hadware_local_upper2lower(strs)
    ! this subroutine is to convert the uppercase letters in the string
    ! to the lowercase letters
    IMPLICIT NONE
    CHARACTER*(*),INTENT(INOUT) :: strs
    INTEGER :: i,n
    DO i=1,LEN_TRIM(strs)
        n = ICHAR(strs(i:i))
        IF(n >= 65 .AND. n <= 90) THEN
            n = n + 32
        ENDIF
        strs(i:i) = CHAR(n)
    ENDDO
    ENDSUBROUTINE hadware_local_upper2lower
The code works fine under x86 configuration. However, it does not work properly under x64 configuration. To be more precisely, the program will only produce the information of the first adapter information while it will produce a list of adapters information in x86 configuration. I  also wrap the GetAdapterIno() in C#,  both the x86 and x64 configuration produces a list of adapter information. Is there any way to make the code works in x64 with Fortran?
