callback function
weichao
I want to simulate the callback mechanism with C and FORTRAN. The projects can be built successfully. But it still have a problem. The function event should print something but it doesn't. I am not a C expert. Anyone could help me?
In FORTRAN part:
module mymod
implicit none
interface
subroutine do_it(str,callback)
!dec$ attributes c :: do_it
!dec$ attributes reference :: str
implicit none
character(*)::str
external callback
end subroutine do_it
end interface
end module mymod
!_______________________
program test
use mymod
implicit none
character(40)::str
external event
str="Event is raised."
call do_it(str,event)
end program
!________________________
subroutine event(str)
implicit none
character(*)::str
print*,str
end subroutine event
In C part:
typedef void (*CALLBACKPROC)(char* str);
extern "C"
void do_it(char* str,CALLBACKPROC callback)
callback(str);
I can't find CALLBACKPROC defined anywhere in the MSVC headers or documentation. But in Windows programming, callback procedures are usually STDCALL...
Steve
Jugoslav_Dujic
Valued Contributor II
Steve, there's typedef for CALLBACKPROC in the code ;-)
The problem is that it's wrong. You need instead (d'oh, I hate that syntax, I have to look back in the sample every time):
typedef void (__stdcall *CALLBACKPROC)(char*, int)
i.e. it must match the prototype of Fortran routine Event. Passing characters between C and Fortran is a bit tricky as there's hidden argument describing length. There are many ways to solve it, depending on what you need with the argument (only reading, reading/writing, writing). One solution can be to terminate it with �:
str="Event is raised."//char(0)
call do_it(str, event)
void do_it(char* str, CALLBACKPROC callback)
{callback(str, strlen(str)); }
Jugoslav
weichao
Thank you,Jugoslav. It works but I don't use __stdcall.
Jugoslav_Dujic
__stdcall is the default convention for all CVF routines. You can change it in project settings though -- did you do that? (Project/Settings/Fortran/External procedures/Argument passing convention). If you didn't, you'd better either use __stdcall or change the setting above to "C, by reference", or you'll get a smashed stack.
Jugoslav
