29281 Discussions
calling fortran dll from visual c++ dll
nandita
I'm using CVF and Visual Studio .NET.
I included the Fortran dll in the C++ project, and the compiler and linker do not give any errors.
However when I try to use the C++ dll in Stata, I get an error message saying that the fortran dll was not found.
any clues on what the problem is?
sabalan
1- If your C++ application is on another computer where CVF is not installed, then you would need some CVF run-time libraries installed on this computer. Download VBFRUN66BI.exe from hereand install it on the computer without CVF.
2- If C++ application is on the same computer as CVF, then check the name, spelling, and argument list of both your CVF DLL and call statement in C++.
3- Check even decorations for exporting your DLL name in CVF. Search for "calling conventions" or "calling fortran from C" in this forum.
Sabalan.
nandita
CVF 6.5, Visual Studio .NET 2003, and Stata 8.2 are all on the same computer.
In C the code is
Code:
extern __declspec(dllimport) void __stdcall fcstata(int *n);
In Fortran
Code:
subroutine fcstata(n)
!dec$ attributes dllexport, alias:'_fcstata@4'::fcstata
There are no compile or link errors.
I included the fortran.lib file in the VC project.
I've even triedsaving the fortran .dll in the VC debug directory.
I have no clue what the problem is.
