can i write the allocatable array like this?
Wang_J_
type fracShp
      real*8,allocatable::s(:)
end type
type(fracShp),allocatable:: abc(:)
allocate(abc(5))
allocate(abc%s(5))
Is the above codes right? The array 'abc' is allocatable, and the array 's' in 'abc' is also allocatable.  Can the compiler get the right address of all the two arrays?
IanH
You need to allocate the array component in each element of abc separately.
[fortran]allocate(abc(5))
allocate(abc(1)%s(5))
allocate(abc(2)%s(22))
allocate(abc(5)%s(66))[/fortran]
Wang_J_
if I allocate it as you did, is everything  legal?   I am afraid that the system can not find the right address of the inner allocatable variable 's'.
allocate(abc(5)) allocate(abc(1)%s(5)) allocate(abc(2)%s(22)) ... allocate(abc(5)%s(66))
Anonymous66
Valued Contributor I
If you allocate as Ian describes, it is legal. When you say your "system can not find the right address," what happens? It would be helpful to see the exact text of the error message.
Wang_J_
In my program there are some access violation without error message. It just displayed in the assemble language. So i can not find where it happened.  i doubt if there are some address confusion.  Moreover,  the memory occupied by my program became more and more large. I have checked the allocatable variables and  pointers, and deallocated them. But the problem was still not be solved. The program is too long to paste out. So is there any advice to solve this problem?
Anonymous66
I would suggest using the /traceback option. This will show you where the access violation occurs in your program.
Wang_J_
where is the /traceback option? Is it still work in the 'Release'  mode or just work in the 'Debug' mode?
thank you!
Anonymous66
Traceback is under   Properties > Fortran > Run-time > Generate Traceback Information. This works in both release and debug mode.
Wang_J_
OK, Thank you!  But if i still can not solve the problem, can you help me to solve it?  If you can give some help, please give me an individual email address. i could sent the program to you. Thank you very much for your advice.
Anonymous66
Hi Wang,
If you can not share your program on this forum, the best option is to submit an issue through Premier Support.
