can not open libguide.lib, where i can download
cheng__wenyu
I need Intel Fortran Compiler 10.1 to make the executable from the command line, in Ls-dyan (finite element software). But I could not get this older version. Then i tried advanced versions (IVS 13 +Vs2011), and it gives me an error:  cannot open file libguide.lib. As I know, it belongs to the obsolete OpenMP library which is in Fortran compiler version 10.1.
In this case, i would like to know where i can find and download the obsolete library which includes libguide.lib, libguide40.lib and so on.
Steve_Lionel
You can't - that is long gone. You need to recompile any sources that were compiled with the old version so that they can use the current OpenMP libraries. You may need to make minor edits to LS-DYNA build scripts to use the later compiler.
cheng__wenyu
Thanks for your answer. I will check it.
