29407 Discussions
can't get value correctly from fortran dll to VB.net back
Lu_Zhang
Hi Everyone,
I can't make the following code working in VS2015 with IVF, though it is very simple. Value C from dll is always 0, not 6.0 as expected. Thanks so much.
//my VB code:
Public Class Form1
    Public Declare Sub DLL_ROUT Lib "D:\Debug\Dll2.dll" _
    (ByVal A As Double, ByVal B As Double, ByVal C As Double)
    Public Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim A As Double
        Dim B As Double
        Dim C As Double
        A = 2.0
        B = 3.0
        Call DLL_ROUT(A, B, C)
        Button1.Text = C
    End Sub
End Class
// my Fortran  dll code:
SUBROUTINE DLL_ROUT (A, B, C)
IMPLICIT NONE
! Specify that DLL_ROUT is exported to a DLL
! and that the external name is 'DLL_ROUT'
!DEC$ ATTRIBUTES DLLEXPORT, STDCALL :: DLL_ROUT
!DEC$ ATTRIBUTES ALIAS:'DLL_ROUT' :: DLL_ROUT
DOUBLE PRECISION A, B, C
C = A * B
RETURN
END
FortranFan
I suggest the following instead based on P/Invoke in .NET and C interoperability in Fortran:
   <DllImport("D:\Debug\Dll2.dll", CallingConvention:=CallingConvention.Cdecl)> _
   Public Shared Sub DLL_ROUT (A As Double, B As Double, ByRef C As Double)
   subroutine DLL_ROUT(A, B, C) bind(C, name="DLL_ROUT")
   !DEC$ ATTRIBUTES DLLEXPORT::DLL_ROUT
      use, intrinsic :: iso_c_binding, only : c_double
      !.. Argument list
      real(c_double), intent(in), value :: A
      real(c_double), intent(in), value :: B
      real(c_double), intent(inout)     :: C
      C = A * B
      return
   end subroutine DLL_ROUT
Steve_Lionel
I'm not sure if FortranFan's suggestion will work, but the reason your initial version doesn't work is that just saying STDCALL changes the arguments to pass-by-value, which makes it impossible to return anything. Add to the Fortran:
!DEC$ ATTRIBUTES REFERENCE :: C
This will match the ByRef in the VB.
Lu_Zhang
It works, amazing! Thanks FortranFan!
Lu_Zhang
This is awesome, Thanks Steve!
Lu_Zhang
Both work very well. Thank you guys!
FortranFan
Steve Lionel (Ret.) wrote:
I'm not sure if FortranFan's suggestion will work, ..
Huh?  It's been only >3.5 years here where readers have been guided to consider the better option with Microsoft .NET code to interoperate with Fortran is to employ P/Invoke: https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/594478
Fdll.f90
module m
   implicit none
contains
      !.. Argument list
      C = A * B
      return
end module m
Test.vb file
Imports System.IO
Imports System.Text
Imports System.Runtime.InteropServices
Namespace Fortran
   Public Class Fdll
      <DllImport("c:\Debug\Fdll.dll", CallingConvention:=CallingConvention.Cdecl)> _
      end Sub
   End Class
   NotInheritable Class Test
      Private Sub New()
      End Sub
      Public Shared Sub Main()
         Dim a As Double
         Dim b as Double
         Dim c as Double
         ' Write header
         Console.WriteLine("*** Test Fortran Interop using VB ***" + vbLf)
         Try
            a = 2.0
            b = 3.0
            c = 0.0
            Fdll.DLL_ROUT(a, b, c)
            Console.WriteLine("c = " + c.ToString("###0.0#"))
         Catch ex As Exception
            Console.WriteLine(ex.Message)
         Finally
            Console.WriteLine("Press any key to continue..")
            Console.ReadKey()
         End Try
      End Sub
   End Class
End Namespace
C:\Debug>ifort /dll /libs:static fdll.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on IA-32, Version 19.0.3.203 Build 20190206
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 14.16.27027.1
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:fdll.dll
-dll
-implib:fdll.lib
fdll.obj
   Creating library fdll.lib and object fdll.exp
C:\Debug>vbc -platform:x86 test.vb
Microsoft (R) Visual Basic Compiler version 2.10.0.0 (b9fb1610)
C:\Debug>test.exe
c = 6.0
C:\Debug>
C:\Debug>ifort /dll /libs:static Fdll.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.3.203 Build 20190206
-out:Fdll.dll
-dll
-implib:Fdll.lib
Fdll.obj
   Creating library Fdll.lib and object Fdll.exp
C:\Debug>vbc -platform:x64 test.vb
C:\Debug>test.exe
c = 6.0
C:\Debug>
Steve_Lionel
When I said "I'm not sure" I meant that literally - I thought it might, but am not familiar with the angle bracket syntax for use in VB code, so I didn't know. I didn't say it wouldn't work. But I knew my suggestion would work and was a smaller change.
FortranFan
Please see this thread from about 5 years ago, especially Quote #2 where I suggest moving away from VB6/COM based approaches with STDCALL, etc. from the bygone 1990s when it comes to working with .NET technologies:
https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/509148
Lu_Zhang
Thank you so much, FortranFan.
