can't install on opensuse 12.1
Matteo_M_
I've been told to install the intel fortran compiler on opensuse 12.1
When I try to install it, there is an error message saying this is not a supported operating system.
The install won't complete, and thus I am failing to execute my orders!
So, perhaps downloading the intel fortran libraries alone might help?
I have tried looking online for instructions on how to do this... But I'm not getting anything.
Please help:
How can I install the intel fortran compiler on opensuse 12.1?
If I can't, how can I install/download the intel fortran libraries?
Matteo Miller-Nicolato
Casey
Have you seen http://software.intel.com/en-us/articles/installing-intel-compilers-on-opensuse ?  It looks geared to the c/c++ compilers and for an older generation of gcc compatibility, but perhaps it can be adapted to work for you.
FWIW I also run on an unsported OS (gentoo) and while the install does complain about missing pre-requisite software, I have an option to ignore that and proceed.
TimP
As Casey said, you must accept the unsupported OS option when installing on OpenSuSE.  I expect it to be relatively easy to install the Intel64 compiler on an x86_64 OS or the ia32 compiler on the 32-bit SuSE, assuming that you have installed the default g++ development system.
The ia32 compiler on x86_64, if you want it, would require you to have installed the 32-bit g++ as well as the 64-bit one.  That is tough to install even on the "supported" OS.
If you have an appropriate license for ifort, you can download the redistributable shared libraries from https://registrationcenter.intel.com so as to support run-time library references for an application built on another computer.
