29277 Discussions
cannot compile anything on 64 bit windows 7 PC
grhadley46
I successfully (I think) installed Composer XE on my laptop, which is a 64 bit machine running windows 7. When I try to build anything (even the Console App template that prints "hello world") I get the linker message "rc.exe not found". I have no idea what this means or what to do different
rc.exe is the Resource Compiler and is part of the Visual Studio support installed by the Visual Studio Shell if you don't already have a supported Visual Studio on the system. Did you have Visual Studio already? Please do this - in Visual Studio, click Help > About. Click "Copy Info" and paste the result into a reply here.
Please also paste (or attach) the contents of buildlog.htm from your Debug or Release project folder.
Lastly, please do this: Start > Intel Parallel Studio XE > Command Prompt > Parallel Studio XE with Intel Compiler > IA-32 Visual Studio 2xxx Mode. Set default (cd) to the folder containing your Hello World program. Type:
ifort helloworld.f90 ( replace "helloworld.f90" with the actual file name)
Copy and paste the entire command window output, from the beginning, into a reply here.
