cannot find -lblas
russel_nurjew
I'am using Ubuntu 9.04 i386. I installed Intel Fortran Compiler. I know that this issue has been disussed yet but all workarounds didn't help me. When ifort-compiling my program I always get one of the following messages:
ld: cannot find -lblas
ld: cannot find -llapack
Going to
/opt/intel/Compiler/11.0/083/mkl/interfaces/blas95/ and doing a:
sudo make PLAT=lnx32 lib I get:
mkdir -p obj
make -f makefile objects
make[1]: Betrete Verzeichnis '/opt/intel/Compiler/11.0/083/mkl/interfaces/blas95'
ifort -module ../../lib/32 -c -o obj/mkl_blas_protos.o source/mkl_blas_protos.f90
make[1]: ifort: Kommando nicht gefunden
make[1]: *** [obj/mkl_blas_protos.o] Fehler 127
make[1]: Verlasse Verzeichnis '/opt/intel/Compiler/11.0/083/mkl/interfaces/blas95'
make: *** [libmkl_blas95.a] Fehler 2
What could be the problem? Please help! Russel Nurjew
Ron_Green
Quoting - russel_nurjew
Going to
mkdir -p obj
You'll need to change your makefile to point BLAS and LAPACK to the MKL libraries. The MKL libraries have those libraries, but the library names are different. I would recommend taking this question to the MKL forum as they may have to help you build the proper module interfaces.
the MKL forum is here: http://software.intel.com/en-us/forums/intel-math-kernel-library/
