29249 Discussions
catastrophic error: **Internal compiler error: internal abort**
Christoph_N_
[***@***]: ifort --version
ifort (IFORT) 13.0.0 20120731
Copyright (C) 1985-2012 Intel Corporation.  All rights reserved.
[***@***]: ifort -c problem.f90
problem.f90(1): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for problem.f90 (code 1)
The minimal example "problem.f90" is
module Nonlinear_Parameters
  type NL_Parm
  end type NL_Parm
end module Nonlinear_Parameters
module Newton
  use Nonlinear_Parameters
  implicit none
  abstract interface
    subroutine NL_func(ut)
      implicit none
      class(NL_Parm) :: ut
    end subroutine NL_func
  end interface
contains
  function f0(f, ut, ndim)
    implicit none
    integer, intent(in) :: ndim
    real*8, dimension(ndim) :: f0
    procedure(NL_func) :: f
    class(NL_Parm), intent(in) :: ut
  end function f0
  function f1(f, ut)
    implicit none
    real*8 :: f1
  end function f1
  function f2(n)
    implicit none
    real*8 :: f2(n, n)
  end function f2
end module Newton
When i change the order of functions f1 and f2 the error disappears.
Christoph
Thanks, I can reproduce this and will send it to the developers. Issue ID is DPD200236554. I will update this thread with any news.
This problem has been fixed for a future major release. In the meantime, please reorder the functions.
