29487 Discussions
catastrophic error in fort 2019 with F90 max/minval function and -check all option
Yann_D_
The compilation crashes with this example (not the real application, just to show)
      PROGRAM minval_example
      IMPLICIT NONE
      integer,  parameter  ::  rp = 8
      type phy
         real(rp), dimension(:,:), pointer      :: v,c,p,T,H,Mach,S
      end type phy
      type(phy), save                           :: phys
      real(rp), dimension(:,:,:), pointer      :: U
      real(rp), dimension(:),  allocatable  ::   bp, bm
      real(rp)  ::  a
      integer  ::  nx, i
      read (5,*) nx
      allocate (phys%p(nx,3), phys%v(nx,3), phys%c(nx,3), phys%T(nx,3), phys%H(nx,3), phys%Mach(nx,3), phys%S(nx,3) )
      allocate (bp(2:nx), bm(2:nx), U(3,nx,3)  )
      do i=2,nx
         a = max(maxval(U(1,i-1,:)*phys%c(i-1,:)),maxval(U(1,i,:)*phys%c(i,:)))
         bp(i) = maxval (phys%v(i  ,:) + a / U(1,i  ,:) )
         bm(i) = minval (phys%v(i-1,:) - a / U(1,i-1,:) )
      end do
      write (6,*) bp(3), bm(6), a
      deallocate(bp, bm, phys%p, phys%v, phys%c, phys%T, phys%H, phys%Mach, phys%S, U)
      STOP
      END PROGRAM minval_example
$ ifort --version
ifort (IFORT) 19.0.0.117 20180804
Copyright (C) 1985-2018 Intel Corporation.  All rights reserved.
$ ifort -132  -O0 -g -traceback   -check all -warn all  minval_example.f
minval_example.f: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for minval_example.f (code 1)
The compilation is successful if one removes the '-check all' option, without any warning.
   Guy.
Steve_Lionel
Please report this to Intel using the Online Service Center.
Juergen_R_R
Valued Contributor II
I cannot reproduce this with the Update 1, i.e. ifort (IFORT) 19.0.1.144 20181018.
Yann_D_
Thanks for your help.
I have downloaded and upgraded with 2019 update 1.
I still reproduce the problem.
ifort --version
I will follow advice of Mr. Lionel
Juergen_R_R
Again, I cannot reproduce this ICE with any of the v17, v18 or v19 compilers.
Yann_D_
We have several versions of Intel Fortran Compiler available through module. Only the 2019 versions show the problem.
$ module load intel/2018.0.128
$ ifort --version
ifort (IFORT) 18.0.0 20170811
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
$ module purge
$ module load intel/2018.1.163
$ ifort --version
ifort (IFORT) 18.0.1 20171018
$ module purge
$ module load intel/2018.3.222
$ ifort --version
ifort (IFORT) 18.0.3 20180410
$ module purge
$ module load intel/2018.5.274
$ ifort --version
ifort (IFORT) 18.0.5 20180823
$ module purge
$ module load intel/2019.0.117
$ ifort -132  -O0 -g -traceback   -check all -warn all  minval_example.f X11 connection rejected because of wrong authentication.
$ ifort --version
$ module purge
$ module load intel/2019.1.144
$ ifort --version
I put the original source file in attachment.
Juergen_R_R
$ ifort2019 -V
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.1.144 Build 20181018
reuter@t00pcx27704:~/Computing/fortran/ifort_pseudo_ICE$ ifort2019 -132  -O0 -g -traceback   -check all -warn all  minval_example.f
This compiles without problems. Seems like something is wrong with your installation. Which type of computer is this? 32bit maybe? Do you source the compilervars correctly?
Yann_D_
Applications run on Linux servers, CentOS 7.5, 64bits.
I test with the configuration file :
$ . /trinity/shared/apps/ccipl/machine-dependant/machine-dependant/soft/intel/2019.0.117/compilers_and_libraries_2019.1.144/linux/bin/compilervars_global.sh  intel64
$ ifort -V
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.1.144 Build 20181018
Juergen_R_R
I just also tested on CentOS 7.5.1804. No ICE.
