character string functions
forall
I am trying to create a compact function for replacing the if block
if(present(optvar))then
var=optvar
else
var=defvar
endif
since it crops up a lot in my codes and I like the more compact form var=myIf(optvar,defvar).
I have overloaded real,integer and logical definitions of var, but having difficulties with the character version, due to Fortran-language constraints in specification expressions.
The following is the best I can come up with, but its still not quite right since it will result in wrong results ("character loss") if len(tsource)>len_If_ch2. If I make len_myIf_ch2 extremely large then it becomes very wasteful, since usual arguments will be 4-5 character strings (but occasionally long file paths as well!).
elemental function myIf_ch2(tsource,fsource)
implicit none
character(*),optional,intent(in)::tsource
character(*),intent(in)::fsource
integer(mik),parameter::len_myIf_ch2=100
character(len=max(len(fsource),len_myIf_ch2))::myIf_ch2
if(present(tsource))then
myIf_ch2=tsource
else
myIf_ch2=fsource
endif
! End procedure here
endfunction myIf_ch2
is it possible to write such a routine in a more robust way? thanks in advance!
ingo_berg
you can try the following code. The length of the return string will be the maximum length of both input strings. It works for me
pure function ite_fss(a_bCond, a_iVal1, a_iVal2)
implicit none
logical, intent(in) :: a_bCond
character(LEN=*), intent(in) :: a_sVal1, a_sVal2
character(LEN=max(len_trim(a_sVal1), len_trim(a_sVal2) ) ) :: ite_fss
if (a_bCond) then
ite_fss = a_sVal1
else
ite_fss = a_sVal2
end if
end function
gregscvf
I think what you want is Pure Function in the length definition of the character function. You then supply the Pure Function to provide the length needed depending on the variables provided. Something like:
Code:
!Max_Length_Char--Tests Character Function
!Returned length depends on length and presence of inputs
MODULE XYS_Mod
CONTAINS
FUNCTION XYStrings(Str1, Str2)
character*(*), optional, intent(in):: Str1
character*(*), intent(in):: Str2
character(Len = XYS_Len(Str1, Str2)):: XYStrings
	if(present(Str1))then
		XYStrings = Str1
	else
		XYStrings = Str2
	end if
END FUNCTION XYStrings
PURE INTEGER FUNCTION XYS_Len(Str1, Str2)
		XYS_Len = Len(Str1)
	else
		XYS_Len = Len(Str2)
	end if
END FUNCTION XYS_Len
END MODULE XYS_Mod
Program Max_Length_Char
use XYS_Mod
implicit none
character*(*),parameter:: CH1='This is the first string'
character*(*),parameter:: CH2='This is a much longer second string'
	Write(*,'(A)')'"' // XYStrings(Str2 = CH2) // '"'
	Write(*,'(A)')'"' // XYStrings(CH1, CH2) // '"'
end
Greg
