coarray mpd error
cepheid
The hello work coarray code
  1 program Hello_World
  2 implicit none
  3 integer :: i  ! Local variable
  4 character(len=20) :: name
  • ! scalar coarray, one "name" for each image. 5 ! Note: "name" is the local variable while "name[<index>]" accesses the 6 ! variable in a specific image; "name[this_image()]" is the same as "name". 7 8 ! Interact with the user on Image 1; execution for all others pass by. 9 if (this_image() == 1) then 10 write(*,'(a)',advance='no') 'Enter your name: ' 11 read(*,'(a)') name 12 13 ! Distribute information to other images 14 do i = 2, num_images() 15 name = name 16 end do 17 end if 18 19 sync all ! Barrier to make sure the data have arrived. 20 21 ! I/O from all images, executing in any order, but each record written is intact. 22 write(*,'(3a,i0)') 'Hello ',trim(name),' from image ', this_image() 23 end program Hello_world
    ifort -coarray hello.f90 -o hello
    ./hello
      File "/opt/intel/composerxe/mpirt/bin/intel64/mpd", line 1545
        except Exception, errmsg:
    SyntaxError: invalid syntax
      File "/opt/intel/composerxe/mpirt/bin/intel64/mpdallexit", line 99
        print __doc__
    ifort -v
    ifort version 14.0.2
    python --version
    Python 3.4.1
    How to solve the mpd error?
    cepheid
    Can anyone help me? Is that the python version problem?
    Unfortunately, our expert in this area is away for the next two weeks. I will see if I can find someone else who might be able to help.
    Our MPI folks say that they support Python 2.2 or later, but the folks I spoke to didn't have access to Python 3.4.1. Are you able to try 2.7 or something in between and see what happens?
