29285 Discussions
comment on many consecutive lines
Mike896
I'd like to ask how to set comments on many consecutive lines in IVF?
thanks.
Mike
Jugoslav_Dujic
Valued Contributor II
A "quick'n'dirty" method to comment out a huge block of code is to use preprocessor:
!DEC$IF (.FALSE.)
!DEC$ENDIF
or, if you're using /fpp switch:
#if 0
#endif
However, that is suitable only e.g. if you're doing code bisection (bug tracing by removing huge chunks of code at the moment). I would never leave such "comment" permanently in the code (code coloring does not work in such cases, for the start).
DavidWhite
Quoting - Mike896
thanks.
Mike
Mike,
All comments in Fortran are line comments only. There is no equivalent of /* ... */ as in C, etc. You need to place ! or C at the beginning of each line to make it a comment.
In visual studio, you can select multiple lines and then use Ctrl-K, ctrl-C to make all lines comments.
David
Jugoslav_Dujic
!DEC$IF (.FALSE.)
!DEC$ENDIF
#if 0
#endif
