common block alignment
lmc
I am getting a lot of common block alignment messages when compiling:
..incspcglo.inc(21) : Warning: Because of COMMON, the alignment of object is inconsistent with its type [IUNOU]
Is this OK or do I need to fix all of these ? A little bit slower memory access is OK with me for right now.
Lynn
TimP
No one can guess whether your misalignments will cause it to be a little or a lot slower. There is also a possibility of error, if you combine compilations by different compilers, or maybe even with different options.
