29391 Discussions
compile complex and real double precision
diedro
Dear all,
I usually compile in this way:
ifort -fpp -r8 *.f90
In this way I have double precision with my real number.
Is there any way to do the same thing with complex number?
Thanks a lot
Lorri_M_Intel
Using the "-r8" switch also affects the size of complex variables.
Are you seeing something different?
                --Lorri
diedro
Dear all, Dear Lorri,
I am working with complex number and MPI and I have noticed some difference in my results when I use MPI or not. I do not know if there is a problem in my code or this difference is normal. The difference is less than 1.e-19.
TimP
If you set -r8 you must call explicitly the d and z blas functions and the like. R8 doesn't adjust mkl calls.
TimP
If you want to eliminate minor variations in results under MPI you should look into the MKL conditional numerical reproducibility feature.
diedro
Dear All, Dear Tim,
I do not use any mkl libraries in this case.
I have notice that this difference does not affect my results.
I think that this small differences are normal, am I right?
TimP
-fp-model source specifically disables optimizations where round-off varies with alignment.  If, instead, you want to assure all ranks achieve full performance and reduce these variations, you would set -align array32byte.
Nick_Papior
-r8 does not correct the MPI data type. You need to specify the correct data type when using MPI.
Note that I think it is BAD practice to force the compilation of programs with such flags. Do so by other means to ensure that it always works.
diedro
Dear Nick, Dear all,
I know that, indeed I use:
  SELECT CASE(KIND(realtest))
    CASE(4)
        MPIdata%AUTO_REAL = MPI_REAL               !Single precision used for real
        MPIdata%AUTO_COMP = MPI_COMPLEX
    CASE(8)
        MPIdata%AUTO_REAL = MPI_DOUBLE_PRECISION   !Double precision used for real
        MPIdata%AUTO_COMP = MPI_DOUBLE_COMPLEX
  END SELECT
So I do not know there is a bug or not
jimdempseyatthecove
A difference of 1e-19 is less than the precision capability of a double (~16 decimal places).
The order in which operations are performed will make such differences
MPI rank 1 or single may accumulate iterating an entire array
MPI rank 2 may accumulate iterating two halves of the array, then reducing the two partial sums.
The two results may differ when the numbers exceed the precision capability and/or where they differ greatly in magnitude.
Jim Dempsey
