29640 Discussions
compile error on different kind types
Blane_J_
Someone please have a look at the following code :
module test
    implicit none
    type :: tp
        private
        integer :: a = 0
    end type tp
    interface tp
        module procedure :: func
    end interface tp
    interface
        module function func(var)
            type(tp) :: func
            integer, intent(in) :: var
        end function func
    end interface
    type(tp), parameter :: var1 = tp(1_1)
    type(tp), parameter :: var2 = tp(1_2)
    type(tp), parameter :: var4 = tp(1_4)
    type(tp), parameter :: var8 = tp(1_8)
end module test
submodule(test)  testsub
    implicit none
    contains
    module procedure func
        implicit none
        func % a = var
    end procedure func
end submodule testsub
Only var4 reports an error :
#6259: This array or function or substring is invalid in constant expressions.   [FUNC]
#7715: Replacing invalid structure constructor by integer 1.   [<NULL_STRING>]
why are there different results while parameters only differ in kind types ?
JVanB
Valued Contributor II
tp(1_4) resolves to func(1_4); the others don't have the right TKR (specifically K). That means that tp(1_4) invokes a non-intrinsic function so it isn't a constant expression. N2137 C7104.
JVanB
Blane_J_
Thanks Repeat Offender, I see.
