29275 Discussions
compile errors when trying to call imsl fortran functions from vc++ project
swarup_1981
Sir/Madam
I am using intel fortran compiler and MS .NET .I tried to call imsl fortran function(LSGRR) from a vc++ project and there are many compile errors.The code is as follows
#include
#include
#include
//#include "avlib.h"
#include "avcrt.h"
#include "link_f90_static.h"
//#include "link_f90_dll.h"
extern void __stdcall LSGRR(double a,double GINV,int TOL,int IRANK);
main ()
int NRA=3, NCA=2, LDA=3,LDGINV=2,IRANK;
double A[3][2],GINV[2][3],**TOL;
for (int i=1;i=3;i++)
for(int j=1;j=2;j++)
A=i+1;
TOL = AMACH(4);
TOL = 10 * TOL;
LSGRR_(A, GINV,TOL=TOL, IRANK=IRANK);
WRRRN_('GINV', GINV);
and the errors are as follows
C:ProgrammeVNICTT5.0includeIntel32link_f90_static.h(2): error C2015: too many characters in constant
C:ProgrammeVNICTT5.0includeIntel32link_f90_static.h(3): error C2015: too many characters in constant
C:ProgrammeVNICTT5.0includeIntel32link_f90_static.h(4): error C2015: too many characters in constant
C:ProgrammeVNICTT5.0includeIntel32link_f90_static.h error C2059: syntax error : '!'
C:ProgrammeVNICTT5.0includeIntel32link_f90_static.h error C2059: syntax error : 'constant'
C:ProgrammeVNICTT5.0includeIntel32link_f90_static.h(2): error C2059: syntax error : 'constant'
C:ProgrammeVNICTT5.0includeIntel32link_f90_static.h(3): error C2059: syntax error : 'constant'
C:ProgrammeVNICTT5.0includeIntel32link_f90_static.h(4): error C2059: syntax error : 'constant'
c:ProgrammeIlogswaroop_examplesc_fortranc_fortran1.cpp(24): error C2297: '*' : illegal, right operand has type 'double ** '
c:ProgrammeIlogswaroop_examplesc_fortranc_fortran1.cpp(23): error C3861: 'AMACH': identifier not found, even with argument-dependent lookup
c:ProgrammeIlogswaroop_examplesc_fortranc_fortran1.cpp(25): error C3861: 'LSGRR_': identifier not found, even with argument-dependent lookup
c:ProgrammeIlogswaroop_examplesc_fortranc_fortran1.cpp(26): error C3861: 'WRRRN_': identifier not found, even with argument-dependent lookup
c_fortran Command line warning D4007 : '/Gm' requires '/Zi or /ZI'; option ignored
Please help me in this regard
Swaroop
The link_xxx.h files are not C include files. They are Fortran files, despite the .h file type. You will need to explicitly name the IMSL libraries you wish to link against in the Linker property page.
swarup_1981
I specified the libraries in the project properties--linker--input--additional dependencies.I specified the path in the project properties--linker--general--library directories.I even specified the paths in tools--options--projects--vc++ direcories.but even then the same errors persist.Can you help me in this regard.
swaroop
See my reply in your other thread.
