29641 Discussions
compile ifort source code in different folder
diedro
Dear all,
I would like to compile a fortran code with ifort. The source code files *.f90 are in different sub-folders.
how can I do?
Put the path to the files in your ifort command. This is no different than using cp or any other command.
diedro
Dear All, Dear Steve,
thanks. The problem is that I have to many files to do that. I have also tried with:
 ifort -r -r8 *.f90 -lmkl_blas95_lp64 -lmkl_lapack95_lp64 -mkl=sequential
but fortran creates the modules outside the folder so I was not able to use then and fortran itself gived me an error in the second compilation for missing module.
Do I have to create a makefile?
I would think a makefile wouid be handy for a large project. But you can use "-module path" to specify where modules should be created (and this location is also added to the include path.)
diedro
Dear Steve, Dear all,
thanks so much
Have a nice day
