Overriding type-bound procedures
Towie__Ewan
Hi there,
I am trying to make best use of Fortran's OOP features and I have a question regarding the overriding of type-bound procedures.
Is there a way in which I can define a type-bound procedure that can be overridden in child objects (objects which extend the base class) and have different dummy arguments?
At the moment I can override type-bound procedures but I have to have exactly the same number and type of dummy arguments. I had been thinking about generic procedures, but I couldn't figure out to tackle the problem.
Ewan
FortranFan
You may want to refer to useful books suggested in Dr Fortran blog here.
Here's a simple example - the above mentioned books offer a lot of further details surrounding such techniques:
module m
   implicit none
   private
   type, public :: a
      integer :: i
   contains
      private
      procedure, pass(this) :: set_a
      generic, public :: set => set_a
   end type a
   type, extends(a), public :: b
      real, allocatable :: r(:)
   contains
      private
      procedure, pass(this) :: set_b
      generic, public :: set => set_b
   end type b
contains
   subroutine set_a(this, val)
      class(a), intent(inout) :: this
      integer, intent(in)     :: val
      this%i = val
   end subroutine set_a
   subroutine set_b(this, ival, rval)
      class(b), intent(inout) :: this
      integer, intent(in)     :: ival
      real, intent(in)        :: rval(:)
      this%i = ival
      this%r = rval
   end subroutine set_b
end module m
program p
   use m, only : a, b
   implicit none
   type(a) :: foo
   type(b) :: bar
   call foo%set(42)
   call bar%set(42, [ 42.0, 84.0 ])
   print *, " base a: foo%i = ", foo%i
   print *, " child b: bar%i, bar%r = ", bar%i, bar%r
   stop
end program p
Upon execution,
  base a: foo%i =           42
  child b: bar%i, bar%r =           42   42.0000000       84.0000000
Towie__Ewan
Thanks! I knew it would be simple in the end.
Apologies in advance for diverging on the topic but do you have to make all object variables in the parent class (the type 'a' in the above example) public in order for any child (extended class) to be able to access and use it?
Typically in my coding style, I use separate modules for each class (type).
Thanks again,
Ewan
FortranFan
Ah, the rules for component accessibility with derived types in Fortran do tend to be somewhat confusing and, some may argue, limiting: the thing to note is the scope of private/public attributes of derived type components is modules.  So if you have separate modules (generally a good design), private components will not be accessible and "getter/setter" methods will be needed to work with such data.
Towie__Ewan
Thanks again, I thought as much but wanted to check my thinking was correct.
Turns out I actually have one of the books recommended by Dr Fortran, the book by Arjen Markus. I will need to read this book a little bit more closely the next time!
I am surprised that he hasn't included Chapman's texts on Fortran, although there hasn't been one released for Fortran 2008 yet I do find the 2003 edition very helpful.
FortranFan
My recommendation will be to first examine these two books:
  1. Modern Fortran Explained - Michael Metcalf, John Reid and Malcolm Cohen, Oxford University Press, 2011, ISBN 978-0199601417
  2. Modern Fortran - Norman Clerman and Walter Spector - Cambridge University Press, 2012, ISBN 978-0521514538
Towie__Ewan
I will pick up a copy of these books, learning the new Fortran 2008 standard is proving to be a bit challenging.
Thanks for all your help.
My post was about books with "Modern Fortran" in the name. There are several other good Fortran books out there, including Chapman's, which I often recommend to people. Perhaps I should add these to the post.
FortranFan
Ewan T. wrote:
.. learning the new Fortran 2008 standard is proving to be a bit challenging.
Once you go through the books in Quote #6, I think you'll find Fortran language itself quite straightfoward, even if verbose.
The challenge you'll find is more in efficient and extensible object-oriented design and its robust implementation using Fortran; the former is inherently difficult, regardless of the programming language, and the latter is presently an issue because of its relatively nascent state, both in terms of compiler capabilities as well as user applications.
