compile-time constant
akuhr
Hello!
I want to compile a very big softwarepackage.
I get very many errors like this:
A kind type parameter must be a compile-time constant.
The line thereto in the source:
real(dp) , intent(in) :: x
With other compilers it is working.
Can I give a compile-parameter to ifort, that it will
accept this statements?
This is the version:
ifort -V
Intel Fortran Compiler for 32-bit applications, Version 9.0 Build 20050624Z Package ID: l_fc_c_9.0.024
Copyright (C) 1985-2005 Intel Corporation. All rights reserved.
Regards, Astrid
bpichon
It is true : DP "must" be a compile-time constant !!!
It is more improbable that it may work on any compiler
(the F95 is clear for this) !!!!!!!!
Probably, DP is defined in a modole that you don't have
compiled before ...
BP
emc-nyc
real(dp) is describing the type of real (but you knew that). "dp" must be known to the compiler before the declaration; typically this means it will be set in a parameter statement in a module which is accessed by a use statement. For this to work, the module must be:
  • successfully compiled and
  • where the compiler can find it.
Modules are not compatible between compilers (e.g., Intel's won't work with PGI's or vice-versa) and not necessarily compatible between versions of the same vendor's compiler.
If you're not using modules, add a statement to the effect of
integer,parameter :: dp = selected_real_kind(p=16,r=300) substituting appropriate appropriate values for selected_real_kind's arguments, as needed.
