I am calling a C function defined in a static library as:
extern "C" long getnumparams(long* modHandle);
Dumpbin shows the object name as:
_getnumparams
which is what I would expect.
My Fortran codedefinesthis interface:
interface
integer function getnumparams(id)
!dec$attributes c, alias : '_getnumparams' :: getnumparams
integerid
end function getnumparams
end interface
end interface
and calls the routine thus:
numparams = getnumparams(myId)
The linker complains that it can't find
Linking...
Creating library Debug/myLib.lib and object Debug/myLib.exp
myRoutine.obj : error LNK2001: unresolved external symbol _GETNUMPARAMS@4
In other words, for an interface declaring a C function, it seems that the compiler is not applying the C attribute, i.e. not removing the @argument size name decoration. Can anyone see what I'm doing wrong, or is this a compiler bug?
btw, I am using CVF 6.6b.
I would say that the interface isn't visible where you're doing the call.Note that the lowercase alias isn't used either.
Thanks for the quick reply Steve. I did manage to fix it almost as soon as I posted the second message! I put the interface into a module and it linked nicely.
However, I am still a bit confused. You say the interface isn't visible when the call is made. The interface was declared with the variable declarations in the subroutine that the C function was called from. The subroutine is in a fixed format file (.for). Thenew module is contained in a free format file.
What part of this is the magic incantation that makes it work?
I would have to see the actual source in order to comment intelligently.
Here is an approximation of the 'before' code :
Code:
subroutine someroutine() implicit none interface integer function getnumparams(id) !dec$attributes C, alias : '_getnumparams' :: getnumparams integer id end function getnumparams end interface integer nparms integer myid ! myid = 12 nparms = getnumparms(myid) end
Moving the interface from this method to a new module fixes the link errors.
Got it. You went past column 72 in the directive, since you're using fixed source form.
D'oh! Is my face red! Thanks for your help Steve.
Happens all the time... Things such as this are why I always use free-form in my own coding.
