compiler -r16 -r8 lapack95
diedro
hi everyone,
I do not why but I have the following problem:
I wrote a program as:
[bash]SUBROUTINE quadraturepoints
REAL    (R16P),  DIMENSION(nGP1D)        :: sGP1D
REAL    (R16P),  DIMENSION(nGP1D)        :: wGP1D
 Inv=DBLE(Coeff1D)
 CALL GETRF(Inv,IPIV,info)  !lapack95
[/bash]
then I compile as:
[bash]ifort *.f90 -L$MKLPATH/lib/em64t  -lmkl_blas95_ilp64 -lmkl_lapack95_ilp64 -lmkl_intel_ilp64 -lmkl_sequential -lmkl_core -lpthread[/bash]
and I have not problem
However I write again the program as
REAL    ,  DIMENSION(nGP1D)        :: sGP1D
REAL    ,  DIMENSION(nGP1D)        :: wGP1D
REAL    ,  DIMENSION(nGP1D)        :: xiCel
REAL    ,  DIMENSION(di,nGP)       :: xCel
[/bash]
and this time I compile as:
[bash]ifort -r16 *.f90 -L$MKLPATH/lib/em64t  -lmkl_blas95_ilp64 -lmkl_lapack95_ilp64 -lmkl_intel_ilp64 -lmkl_sequential -lmkl_core -lpthread[/bash]
and I get the following error:
[bash] There is no matching specific subroutine for this generic subroutine call.   [GETRF]
[/bash]
I try also with
[bash]-r8[/bash]
but I get the same error
What is the problem?
What's wrong?
Thank you very much
mecej4
There is no support in the standard BLAS and LAPACK libraries for performing linear algebra operations on REAL*16 arrays.
For example, to do the y <= a.x + y operation, one calles saxpy for REAL arguments and daxpy for double precision arguments, but nothing is provided for higher precision.
If you look at the LAPACK sources, you will find build instructions for
make single
make single double
make single double complex
make single double complex dcomplex
but no
make quadruple
diedro
hi,
thank you
so I will compile i double precision with r8
