composer_xe_2013.0.079 - fortran
Simone_Ferraz
Dear all,
I'm using the fortran (ifort) composer_xe_2013  to run a climate model. I'm getting the error message below:
Insufficient memory to allocate Fortran RTL message buffer, message #41 = hex 00000029.
My linux is fedora 16, intel core i7 and have 3.4Gib of memory.
Anyone have any suggestions?
thank you
My guess is that you're running a 32-bit application that is right at the edge of the 2GB virtual memory limit. Can you build and run it as a 64-bit application?
Simone_Ferraz
Yes, my linux is 32bits, i'll exchange to 64bits... thancks Simone
