conditional compilation of DLLEXPORT attribute
Matthew_Nicoll
I have a library of routines from which I create an object library (.lib)  and a DLL (.dll).
I currently use a custom pre-processor which removes the  "!DEC$ATTRIBUTES DLLEXPORT :: name"  statements, (and one or two other DLL-specific statements), when I am compiling for the object library.
I am wondering if I can avoid using a pre-processor.
Would it matter if I left the "!DEC$ATTRIBUTES DLLEXPORT :: name" statements in when compiling for the object library?
Steven_L_Intel1
Having DLLEXPORT directives in code not built into a DLL is "mostly harmless". The code will work fine, but the linker will create an export library when the executable is linked, which may be annoying.
IanH
You could use module definition files or command line options to specify the procedures to export, as an alternative to DLLEXPORT directives.
