29383 Discussions
configuring project that uses visualstudio and fortran fails
aymanhab
I'm trying to build a dynamic library on windows that needs both C/C++ and Fortran. Using the recommended ifx fails to create shared libraries on windows during CMake configuration as option not supported. Will this be supported any time soon? Using ifort also fails for a different reason (Can't compile a simple fortran program link: unknown option -- s). My environment is mingw64 but trying to build shared library that use native libraries on windows. Project I'm trying to build is https://github.com/coin-or-tools/ThirdParty-Mumps
-Ayman
Devorah_H_Intel
Can you provide the cmake file and build options used? As well as the CMake version.
