control id number
gfr1
How can I get the edit control number during program execution. I want to determine if the current focus is a button.
Jugoslav_Dujic
Valued Contributor II
You weren't very precise, but I guess you need something like:
USE DFWIN
IF (GetFocus() .EQ. GetDlgItem(hParent, IDC_MYBUTTON)) THEN
   !Do something
The key is GetDlgItem function -- it returns handle of the control on the basis of its ID. Also, the code could be rewriten to use GetDlgCtrlID instead (which does the reverse). hParent is handle of the control's parent window -- if it's a dialog, use Dlg%hWnd.
Jugoslav
