I want to copy some text (character area) from my quickwin-application to the clipboard and read from the clopboard. Is there an examle how this can be done. Thanks.
Solved, found an example
Perhaps you could post some code or point others to the example you found?
Here is some example I worked out a couple of years ago:
I just tested that and it still works almost error free. I am getting an error 1418 on the call of
Kind regards,
Jrg Kuthe
www.qtsoftware.com
[bash]! Last change: JK 1 May 97 7:58 pm
SUBROUTINE PrintErr
USE DFWIN
PRINT*,'Error code= ',GetLastError()
END SUBROUTINE
PROGRAM ClipBoard
USE DFWIN
IMPLICIT NONE
CHARACTER, DIMENSION (:), ALLOCATABLE :: CBCopy
INTEGER (KIND=HANDLE) :: hWndNewOwner, hClipboardData
INTEGER (KIND=DWORD) :: CBObjectSize
INTEGER (BOOL) bRet
INTEGER :: ErrorCode, lpClipboardData, lpCBCopy
PRINT*,'Program ClipBoard returns current clipboard contents (text).'
hWndNewOwner = NULL
IF ( OpenClipboard(hWndNewOwner) ) THEN
hClipboardData = GetClipboardData(CF_TEXT)
IF (hClipboardData == NULL) THEN
CALL PrintErr
ELSE
PRINT*,'ClipBoard handle = ',hClipboardData
CBObjectSize = GlobalSize(hClipboardData)
PRINT*,'ClipBoard object size = ', CBObjectSize
! lock clipboard handle and get pointer to the beginning of the block
lpClipboardData = GlobalLock (hClipboardData)
! allocate memory to copy clipboard contents to
ALLOCATE(CBCopy(1:CBObjectSize), STAT=ErrorCode)
IF (ErrorCode/=0) THEN
PRINT*,'ALLOCATE failed, ErrorCode = ',ErrorCode
ELSE
! copy clipboard memory contents to CBCopy (use CopyMemory function)
lpCBCopy = LOC(CBCopy)
CALL CopyMemory( lpCBCopy, lpClipboardData, CBObjectSize )
!IF ( .EQ.NULL) THEN
! PRINT*,'CopyMemory failed'
!ELSE
PRINT*,'Clipboard contents: ',CBCopy(1:CBObjectSize)
!END IF
! Unlock clipboard block
bRet = GlobalUnlock (hClipboardData)
IF ( bRet == 0 ) THEN
ErrorCode = GetLastError()
PRINT*,'GlobalUnlock failed'
IF (ErrorCode == ERROR_ENVVAR_NOT_FOUND) THEN
PRINT*,' ErrorCode = ERROR_ENVVAR_NOT_FOUND; do not ask me why this...'
ELSE
PRINT*,' ErrorCode = ', ErrorCode
END IF
END IF
! deallocate CBCopy
DEALLOCATE(CBCopy, STAT=ErrorCode)
IF (ErrorCode/=0) PRINT*,'DEALLOCATE failed, ErrorCode = ',ErrorCode
END IF
END IF
IF (.NOT. CloseClipboard() ) CALL PrintErr
ELSE
CALL PrintErr
END IF
pause
END PROGRAM
[/bash] I just tested that and it still works almost error free. I am getting an error 1418 on the call of
[bash]CloseClipboard() [/bash](meaning: Thread does not have a clipboard open). Maybe someone has an idea what's wrong.
Kind regards,
Jrg Kuthe
www.qtsoftware.com
The documentation of CloseClipboard says:
Return Values
Nonzero indicates success. Zero indicates failure.
So replace
IF (.NOT. CloseClipboard()) CALL PrintErr
with
IF (CloseClipboard()==0) Call PrintErr
The document also says that the return value is of type BOOL but keep in mind that a BOOL is not a LOGICAL. (see http://software.intel.com/en-us/forums/showthread.php?t=41785&o=a&s=lr)
