crash deallocating passed pointers
martymike
We want to create a structure holding strings that vary greatly in length that can be modified during program execution. So we are using deferred length pointers. However, we are running into a problem deallocating them later. Below is a greatly simplified program that demonstrates the issue. The deallocate in the main program works. The one in subroutine a crashes.
      character(:), pointer :: ptr1
      character(:), pointer :: ptr2
      integer ierr
      allocate(character(12) :: ptr1, stat = ierr)
      ptr1 = "ABCDEFGHIJKLM"
      ptr2 => ptr1
      deallocate(ptr2)
      ptr1 = "MLKJIHGFEDCBA"
      call a(ptr1)
      contains
      subroutine a(ptr)
      ptr2 => ptr
      deallocate(ptr2)
      end subroutine a
      end
martymike
Forgot to mention, running IVF 15
Kevin_D_Intel
It appears this should work when using ptr2. It also fails with the 16.0 compiler. Deallocation is successful inside the contained routine when using the dummy argument itself. I submitted this to Development.
(Internal tracking id: DPD200377888)
