creating templates
Rachel_Jordan
I am migrating from CVF. My CVF projects contain input/output files in several folders. How do I set up a template to access these files? I have not used/created templates before.
Rachel,
Welcome to the forum. I am not sure what you mean by "templates" here. Whatever you did in CVF should work in Intel Visual Fortran. Are you just trying to make the input/output files visible in the "Solution Explorer" pane? You can add them to the project as if they were source files (feel free to create a virtual folder in the project for these files if it helps organize them) and you'll be able to open them in Visual Studio.
Rachel_Jordan
Steve,
Many thanks for the reply. Your suggestion was helpful and I am up and running. The IVF compiler invoked this way picked up a few bugs which did not appear when I used the MVS CVF to IVF converter. I good thing! Think I am all set.
Rachel,
You are very welcome. Feel free to stick around and pick up tips from the community, or at least post again if we can be of assistance.
